Predator 420CC Build
awmayhall
Maryland Heights MO
Hey guys, I am new to this forum here so nice meeting you all!
As the title suggests I am currently working on a Predator 420cc build packed full of upgrades. I just picked up this engine at the local harbor freight near Saint Peters MO, and started tearing into it.
I've already got a new ARC 6272 billet rod and ARC 6672 billet flywheel. Governer has been removed already and I've got a new Mikuni Flatslide, 34 mm carburetor and manifold on order. Can't wait for those to get in!
Whats left to do is decided on a replacement upgraded camshaft and what specs to mill my head to and the various upgrades that come with that. I am primary building this motor for some serious low end torque. So I am probably going to shoot for a compression ration close to 10-11:1 using a 280 series cam. I am open to suggestions though!
Now when I first unboxed the engine I immediately noticed there have been some changes that I am a bit unfamiliar with. First and foremost the predator head for the 420cc has changed dramatically. I took it off and I have uploaded some pictures showing left the 2014 Predator 420cc head and right the 2012 predator 420cc head.
You can see for yourselves that the two heads are completely different. Has anyone seen this on other 420cc Predators? I am interested to hear what you guys have to say on this.
Also that stock intake valve is 38mm diameter?! My 2012 stock is 36mm. So why the change? Hopefully those pictures are high res enough, but the intake valve doesn't have a whole lot of clearance to the side and bottom of the head. So I guess milling this head down on my Bridgeport won't be all that worthwhile....
I have yet to measure the volume of the head, but it just looks smaller that that of the 2012 head. The manual says stock compression ratio is 8:1. I am a bit worried that they added material to the top of the cylinder making the distance from TDC to the mating half of the head larger. Thoughts?
First off....Welcome to the forum and thanks for filling out your profile....
I'm not familiar with either of those engines.....but here are some thoughts....
It appears the new one is a hemi head while the old one is more a flat-head if I am interpreting the pics correctly.....
So that brings up some interesting questions.....what kind of clearances are you starting with? ??! Not quite as easy to tell with that set -up.....
If it were me...I would me....I would clay the heads 2 ways before I did anything.....one would be the valves....to see what kind of clearance you have to the piston....then that gets interesting.....because how do you guesstimate how much change milling makes to valves that travel at an angle to the cylinder.....I would guess it would be less....follow my thinking?????
The other is to clay the entire combustion chamber with the cam and spark plug removed....(so the excess clay has somewhere to go).....
Again....if it were me....for that I use some Zubber (ToysrUs)....or if I had the time and patience....silicone ...(RTV)...so I could dissect it wth confidence.....
Then also account for added lift...(if any) with the new cam and when fairly confident that everything will clear....install the new cam....valves...and everything else and reclay the valves before I milled the head.....
Just my 2cnts......
Just my 2cnts......
Something tells me you like playing with clay as a kid (or didn't get to play enough....). LOL
Welcome to the forum awmayhall
awmayhall
Maryland Heights MO
Hey everyone, first of all thanks for all the welcomes.
Sorry for not replying sooner as I have been pretty busy with work! Anyways,
Poboy kartman, thanks for the suggestions. As it turns out both 2012 and 2014 engines are flat head pistons.
Only the 2014 piston has valve indentations. I believe the stock gx390 pistons are a bit different as they have a dip in the middle of about a millimeter or two deep starting something like 4 or 5 millimeters away from the outer circumference. -At least so I recall.
I have attached some more images showing the pistons. The one from the 2012 is a spare I have lying around so I am holding that one.
I am going to do a volume check of the head and the cylinder as soon as my new burette gets in seems I can't find the old one around the shop.... Anyways, the clay idea is not a bad one either! I will give that a shot here in the next day or so and report back on my findings.
hmm perhaps I can use the 3D scanner at my work to get a solid model of the head! Might be able to determine the feasibility of milling it down a bit better that way! XD
Thanks again guys! I'm shooting to get about 25hp -30hp out of this new build. Ive been designing a pretty cool kart frame in solidworks for the past few months. I am hoping this will be the beast powering it! I may share some of the designs for suggestions in a different thread soon.
-Andrew.
-Andrew.
I can't ever seem to find a brunette when I need one either......WAIT!!!.....Oh....burette.....yeah I know exactly where mine is at.....
Well...that's not what I was expecting on the piston.....so....really....cc'ing the combustion chamber on the head should get you there.....everything else is just measuring and calculating.....
And the only thing you need to clay is the piston valve relief/ valve clearance......:thumbsup:
