Predator 301cc 8hp w/ 1" bore centrifugal clutch
Hairless Hippy
LOCATED IN CONNECTICUT, NOT SURE I WANT TO SHIP.
I have for sale a new* 301cc Horizontal shaft engine with 10 tooth centrifugal clutch.
This is an engine that was going to go on a go kart but never got there. it has ran and does run first pull. So I guess not brand new but has never been used for anything other than just breaking it in.
This engine has a 1" bore diameter.. This is not a $30 clutch.. more like $100.
The engine new at harbor freight is $230.
i will sell separately if necessary. $150 for engine.. $50 for clutch.
This Predator 301cc gasoline engine has gas-saving overhead valves for cooler, cleaner performance and longer life. The horizontal shaft is ball-bearing mounted, making this gas engine an ideal replacement for most standard engine configurations. The powerful gas engine features a durable cast iron cylinder making it the perfect replacement engine for a lawn mower, log-splitter and dozens of other machines.
Upgraded engineering and construction for improved lifespan
Durable cast iron cylinder withstands wear and abuse
User-friendly controls for easy starting and operation
Fuel shut off for safe transport
Ball bearing support shaft for long life
For use on: pressure washers, compressors, log splitters, vacuums, tillers, water pumps, chipper/shredders, blowers
Specifications
Name 8 HP (301cc) OHV Horizontal Shaft Gas Engine EPA
SKU 61415
Brand Predator Engines
Application pressure washers, compressors, log splitters, vacuums, tillers, water pumps, chipper/shredders, blowers
Certification EPA
Diameter 80 mm
Engine displacement (cc) 301cc
Horsepower (hp) 8
Maximum speed (rpm) 3600 RPM
Maximum Torque (ft. - lbs.) 12.9 ft. lbs.
Mounting pattern 195.5 mm L x 82.5 mm W - 96mm W (7.7 in. L x 3.25 in. W - 3.78 in. W)
Shaft rotation direction Counter clockwise
Start type Recoil
Product Height 17.25 in.
Product Length 15 in.
Product Weight 54 lb. / 24.5 kg.
Product Width 17 in.
Shaft length (in.) 3.48 in.
Shaft Diameter 1 in.
Shipping Weight 63.40 lb.
Stroke length (in.) 60 mm
Glider_Pilot
Converse Texas
i am interested in the clutch. my only question: does it engage? i have the exact same motor and have had quite a bit of trouble finding one.thanks
I cannot see why it wouldn't engage. Clutches engage at rpm's that are less than the max rpm's an engine puts out. What sort of clutches were you looking at?
DueceCassel
summerville, sc
I would like to buy both if we can figure out shipping fees. I'm ready with the money and look forward to talking with you. Ihave been wanting this predictor 300cc but I just didn't think I cfford . In the club. I think this would be perfect for me and I would be greatly appreciated
