Predator 301/ 8HP build
John.gaughan
What's up dudes. I picked up the predator 301 a week ago. Seems like it has potential, if the right parts waken it up. It's not looking like they have any aftermarket parts for it at the moment. Is there any flywheels that will drop right in? I was doing some research and was reading that it is a clone of the gx 270/290. Will the 270 billet flywheel work for this engine? Any thoughts/ideas would be appreciated.
Why go straight for the flywheel? That's usually the second to last item to replace...
If it is, in fact, an exact copy of the GX270, chances are, the Honda flywheel will fit; however, if the taper of the shaft is different by even 1° or the diameter is different, the flywheel won't be in full contact with the shaft & may create problems...
Welcome to the forum...
Poboy kartman
Senior Moments Member
White Settlement Texas
Yeah....sorry....new engine....new ground.....pioneer area here....probably not a lot of folks to do that yet.....(lack of parts online should be a clue).....you can do the basic mods that are covered for the 212 without parts....outside of that...you may be on your own.....sorry....
John.gaughan
Ok so I ordered a hop up kit. It came with stronger valve springs. I took one side off. When I was trying to put the stronger spring on, I couldn't hold it down long enough to put the retainers in. So I went to HF and got me a spring compressor. The tool is junk. Everytime I get it close to the distance I need, the dam spring pops out. Any suggestions would be appreciated.
If you haven't taken the governor out, then the stronger springs are going to do nothing for you. If you have taken the governotr out, and havent replaced the rod with a billet one, then the stronger springs are going to do nothing for you (besides potentially destroying your engine.
If the governotr is removed, and you still have the stock rod inside, then the original valve springs will save the engine from over revving and potentially exploding. The valves will float before a critical RPM is reached that the stock rod can handle
John.gaughan
Fabroman- it came with an exhaust intake timing key and new springs
it also came with a bigger main jet
I've already gapped my plug. Intake and exhaust and cut my cooling fan blades (every other one)
Please don't create multiple posts minutes apart, there is an Edit button in the lower right corner of your posts, please use it!
Just because the springs are there doesn't mean you have to use them...
We are trying to help you based on many years of personal experience; as landuse already said, unless you have a billet conrod, by installing the heavier springs & removing the governor, the stock conrod will become a time bomb which will destroy your engine... but, what would we know, right?
John.gaughan
Wow, I'm just trying to Learn. I'm new at this. No need for an attitude. I have been using the affordablego kart site before I came here and clearly in basic mods it talks about valve springs for removing governor. Not anywhere in that list of basic mods does it say to get new rods. So calm your roll. This site isn't that serious
John you're right, just go ahead and finish what your doing. It will be fine, Keep calm. It can't blow up if it will not rev right? :rolleyes:
:feedtroll:
Like Fabroman said, we are just trying to help. If you install the stiffer springs without the billet rod, there is a good chance that the stock rod will snap because it is going so fast. The rod will then punch a hole through your block, ruining the engine for good. We have seen pics of this happen.
I don't know why affordable gokarts sells those springs without a billet rod. You would think they would know better
...& we are trying to teach you but, people only learn when they listen & absorb the information given to them...
Regardless of what info appears on the AGK site, we have personally seen what happens when a stock conrod is overrevved & the result is CATASTROPHIC! It WILL destroy your engine...
Heavy valve springs can be safely used IF the governor is left intact; once the governor is removed, the valves start to float at around 5000rpm (as described on the AGK site); by upgrading the valve springs, the engine is then free to rev to whatever RPM it wants, upwards of 8000rpm; however, the stock conrod is only designed to run to around 6000rpm... do the math...
