Hey I have a few questions about removing the governer, so I have the Hemi model, I’m wanting to know if I will need to get a new gasket prior to this or will I beable to use the original gasket? I also would like to know if I would beable to only remove the gear and the small clips and leave the governer arm inside of the engine, or would that mess with the shaft and gears? I don’t want to have to thread it and put a bolt inside of the engine cut it off and every few days make sure the nut is still tight! Thanks for the feed back!!
