Predator 212cc vs Greyhound 196cc power difference
e85
The great NW
I know their almost the same 8.9 ft-lbs compared to 8.1 ft-lbs. But has anyone actually felt the difference between two? I have heard it was quite noticable but I wanted more opinions, what are your thoughts?
Badot
I wouldn't think there would be enough of a difference to notice much. Take that last sentence with a grain of salt though, I'm no expert on that sort of thing. You also have to remember that since these are chinese engines, there's probably enough variance in them that one engine may have a whole horesepower more than another just because the low tolerance parts happen to line up better, or the kid at the factory didn't have the throttle stop screw in as far as it should be, installed a gasket upside down... etc.
Blazkowiez
Kart Aficionado
Houston, Texas
I've mounted 4 of them so far and am in love so far. I've been amazingly impressed and frightened how strong these are compared to some of the other engines. One was far more but they were all good.
redsox985
PA
Blaz, how does the overall quality of the motor look? Also, what are these rip offs of?
Blazkowiez
Kart Aficionado
Houston, Texas
It still looks like a Honda GX clone, they've changed some items on the motor to differ slightly but its super similar as far as we've seen. The quality honestly looks improved, i've noticed an improvement in the oil caps, block design, gas cap, linkage and hook-ups, and the tank was move back to standard style. Also while the air filter uses a really horrible quality foam filter it also fits a standard tecumseh filter as a replacement, so bang on for ripping design there. Its just awesome, you'll be surprised when you try one out.
redsox985
PA
Too bad I've sliced and diced my clone other wise I'd try to run it into the ground and use my 2 year warranty.
Blazkowiez
Kart Aficionado
Houston, Texas
There are wire switches and conduit clamps already installed, you still need to install a return spring but hook-up is super easy. Its actually a good thing because now people will stop doing wacky set-ups.
