Predator 212cc review...
pontiacman74
butthole surfer
Wausau, Wisconsin
Well im on day number 4 with the Predator 212cc. I have 2 tanks of gas through it. I really do not think the engine is as :censored: as some people are making it to be. I have BEAT the hell out of it these past days! It still starts in 1 pull and runs great! The only thing I have found to be bad about it is the oil sensor, When doing donuts or just making a really sharp turns to the right seems to make the oil sensor shut it down. It runs real strong. Very responsive on the low end. I can do real burnouts with it( but there is no smoke I mean squeal the tires and leave black marks). I really did not like the airbox design though its not the best. I did like the gastanks fuel filter built in there but it does slow down refueling. I am actually really happy with this engine I say go stcok up on them! There is also more power to be had by adjusting the carb.
redsox985
PA
Like Devino said, just unplug the sensor. That was an issue on the blue clones as well. People are making a deal of the filter, my blue clone has one. Does anyone else have one of these in their blue clone? For your airbox, you can probably just remove the whole cover and run it as a bare filter, or put a different filter on it. Also, you can't gain power by just through carb adjustments.
pontiacman74
butthole surfer
Wausau, Wisconsin
The predators air filter is just a square piece of foam between the top and bottom half of the airbox. I will post pictures to show you what I mean.
oldbikerarlo
Old guy
Marana, Az.
I was At HF the other day, checked out the Preditor and the air cleaner is pretty sorry. defenitly needs a better one before used as a kart engine
redsox985
PA
Much like a weed wacker? Just an oiled piece of foam before the carb?
CaptCanadia
Acton, CA USA
I think they look alienish. The exhaust and filter have an odd shape..weird but gives it character..maybe not performance.
pontiacman74
butthole surfer
Wausau, Wisconsin
A little update here I put 4 miles on the engine today and it still runs and starts 1 pull. I changed the oil today and it looked good. I put in some Mobile1 15w 50 and some lucas.
r_chez_08
Should be in the shop...
Cornwall, UK
I agree- they look like something from alien vs predator.
My clone just has a single element foam filter, and always has done. It runs fine.
Badot
My blue clones have the mesh cup in the fuel tank as well...
A square chunk of foam as a filter though? That's the same thing the little 2.5s HF used to sell had, and I would imagine those would even have more surface area than in that little airbox on the predator.
My blue 6.5s all came with oval shaped paper filters with foam over the outside.
What I'm really interested to see would be the quality control of the Predators vs. the old blues.
pontiacman74
butthole surfer
Wausau, Wisconsin
Besides the air filter this engine is better imo than most clones it has a cork valve cover gasket and all the gaskets are good gaskets. It also has an iron cylinder bore I did not get pictures but I saw it when I had my head off. I could not believe how flat the head and deck of the block were. I think it looked milled from the factory.
r_chez_08
Cornwall, UK
Lol.
Theres nothing stopping you putting a straight pipe on your clone, but tbh the majority of users of honda and clone engines (non motorsport users) want their engines to be quiet and clean.
