predator 212cc hemi
ericb
just bought this engine for my drift trike so its stock any suggestion on up grades? 300-500 budget. i would want it torquey. not familiar with the whole rebuild. this will be my first build. i would want to take the governor out. so i need to know what parts i need so i wont blow the motor. I was thinking a cam, springs, flywheel, rod, intake filter, exhaust, and jet the carb .Do you know what's a good set up with part number with a budget of 300 to 500? Sorry I don't really know which way to go with all the option they have for each item. I don't know what will work the best with each other to get the best combo. also I don't know if I would need a pulse fuel pump? or at what degree my timing should be to get the best performance with all the upgraded parts? also I need help hooking up the throttle? do I need extra parts for that? thanks and hope to hear from you guys
KartFab
Dallas, TX
intake/exhaust/jet kit for predator, this is probably the best deal on that part
direct throttle just search "predator racing throttle kit" there are a bunch of ways to do it, you can get a cheap kit for $8 or a bolt on plate that has one built into it for about $30.
if you want it torquey, you do not want to go with a traditional racing cam. but an overall improvement across mid to high range cam. I cant tell u which one, but usually the "mild" cams are best for this. The cam will come with a "cam card" that will tell you what to set your timing to, so just remember that timing depends on your cam, but is usually 2-5 degrees advanced for gas, more for methanol. Don't advance too much or you lose out on torque on the low end.
flywheel is arc billet for predator HEMI
connecting rod is stock/std length for predator HEMI
for springs, again, springs are dependant on CAM, so just get the springs that are reccomended for the CAM. One thing people screw up on is choosing the wrong springs, and losing hp. Springs are a trade off. they have more parasitic drag the higher the tension. More hp is robbed on the low end with springs, so dont go all out on some crazy dual springs for a dragster or 8k rpm running race engine. Springs will have the least amount of hp robbing right before they float, so just choose the springs based on the cam, and if in doubt, get springs that are slightly heavier than stock or "stock appearing" and you will probably be good to 6500-7k rpms.
intake and exhaust and jet and adapter will run 100
flywheel about 100, rod about 60
cam about 60
springs like $5 each.
you can also get out a dremel and do a mild port job if you are feeling extra DIY, but most people will shy away from that cuz its king of daunting and messy and if you dont know what you are doing, you could screw it up
also for torque, you really cant get muchmore torque on the LOW end without increasing compression. I have heard that you can get a gx160 or similiar smaller HEAD and bolt it to the predator, which will give you more torque,but you will need to really REALLY look into this. At a bare minimum you will need to buy a valve cover that matches the head.
Also, waht I am doing (not on predator but old briggs) is in conjunction with all my other performance parts, I am regearing, so i get more torque to start off with and wont be going 50 mph when the engine tops out. It will just have more torque, and get to 40 mph much faster.
Also, minor upgrades that help but dont give you much gains are:
index the spark plug and/or
get a spark plug that takes up more space in the combustion chamber that will increase compression.
run it on racing oil, (thinner, synthetic)
