No one is going to mention raising the compression ratio?
Something that actually increases the pulling power of the motor, to help accelerate quicker with the same gear ratio?
Anyways deleting the head gasket should raise the ratio to around 9.5 to 1, Maybe 15% increase in torque? Piece of glass, some grinding compound, much cheaper than even a budget cam.
Then you might have a reason to run premium fuel lol
I thought if the governor was removed that a new cam, rod, and flywheel were needed as we’ll?.....or is that strongly suggested.
I’m going to agree with this, you can get as wild as your budget will allow. I’ve spent a lot of money on a couple of predators, and they are bad fast, but it took a LOT of money to get them to where they are.This depends on how much money you want to spend on it. Little money = little power gains. Big money = big power gains.
If you want to go cheap then do a governor removal, billet rod, and 18lb valve springs. You should be around 85 or 90 bucks at that.
If you want big power and rpm, I'd do the gov delete, billet rod, some porting, HOT265 cam, billet flywheel, 24lb valve springs, oil sensor delete, mikuni, run maybe some 93 or higher. You should be around 300 bucks for that.
---------- Post added at 09:50 AM ---------- Previous post was at 09:49 AM ----------
That's a nice kart by the way.
