realfast89gt
Kart Krazy!!
I bought they newest 212cc engine from hf and one of the first things i did was get a new spark plug(ar3910x). Everything i have read online shows nothing but good things with this combination but my engine never seemed to run right with this plug.
From the first time i installed it i felt a loss in low end power. Then after about 20 minutes the engine started misfiring. I removed the plug and installed the original plug and it ran fine. I figured i would try again once i installed my header and air filter so i put a new ar3910x in. Ran ok, but soon after same thing....misfiring and loss of power.
Any ideas? I have put a few hrs on this motor and it continues to run perfect with the original plug. Is it possible to get 2 defective plugs back to back?
The spark will follow the path of least resistance, which means that it's typically going to "pick a favorite" electrode and go to it 99% of the time - which means that the other 3 electrodes are shielding the spark. Your engine is leaning out because of this shrouding, and I'll bet the plug is trying to foul out as well. Re-jetting the carb is putting a bandaid on the real problem, and will only cost you time, effort, and more fuel out the tailpipe.
