Sorry not sure why it is posting my pictures upside down, I am uploading directly from my cell where they are right side up
•MERGED•
well first: get rid of that sprocket!
it is NOT going to work with a 212 (TC or not doesn't matter)
it's clearly meant to be powered by an internally geared engine, seeing the axle likely some gy6.
Anyways, get rid of it and once you know what ratio you will end up needing, you can buy a new one (a quick guess would be 75 teeth or so depending on the rear wheel size and weight of tart/driver combo)
Thanks for a quick reply. Unfortunately I am completely new to this so I have no idea about figuring out what sprocket I will need. The previous motor was a gy6, as this started its life as a yerf dog 150 spiderbox...best guess is model 32092. I purchased it in hopes to be able to learn with my daughter and son as we go, but thought all I would need to do is put a Predator in there and hook up a clutch and chain and off we go. Since then I decided to do it right so we have stripped sanded and painted the whole frame, purchased new shocks, ball joints, bushings, tires, etc. Now we are to the motor and I am lost haha and a bit disappointed as my kiddos were relying on me... any idea where to go to read up on or learn how I can make this work? I am not against a different power plant either just didn’t want to brake the bank too bad, pics for what it looks like put together.
•MERGED•
FYI I flipped the pics on my phone and they still upload upside down ����
