predator 212 upgrades
gsegovia
houston,tx
So I bought the 212 predator. What kind of ho gain a should I see with cam, valve spring, k&n, and exhaust upgrade.
kendelrk
redneck engineer
westland michigan
as for power gain i have no idea, but when not using a billet flywheel and rod it is recommended not to change valve springs. without the use of billet and an ungoverned engine valve flutter keeps the engine from blowing the con rod and mythical flywheel. when springs are changed there is no saftey net and anything could happen at any moment
Bluethunder3320
When you say rod you meen the piston rod? What kind of power gain should I see. Thanks
he means connecting rod (piston rod)
you wont get any performance upgrades from a billet rod. but it prevents your engine from blowing up. stock rods are only good for around 5,000 rpm (if that)
gsegovia
houston,tx
I understand. How about if I changed the piston, I figure if I world be replacing the rod why not the piston. I could go with a flat top and gain some more compression. Would I have to upgrade the head. Or stronger head bolts will do.
gsegovia
houston,tx
Never mind on the piston question, I just read some descriptions and I have no idea on how you will mill a piston. I do have experience with engine building but not modifying pistons.
