gsegovia
So I bought the 212 predator. What kind of ho gain a should I see with cam, valve spring, k&n, and exhaust upgrade.
only upgrade valve springs if you have an ungoverned engine with billet flywheel and rod
he means connecting rod (piston rod)When you say rod you meen the piston rod? What kind of power gain should I see. Thanks
I understand. How about if I changed the piston, I figure if I world be replacing the rod why not the piston. I could go with a flat top and gain some more compression. Would I have to upgrade the head. Or stronger head bolts will do.
