Predator 212 timing
matiask1
Santiago,chile
:welcome2:Hello ,
Im building my first engine and I have a few questions
This is what I have but I havent assembled it
Arc billet flywheel 32
Mikuni round 24mm one size bigger for altitud running carb with performance muffler
18cc honda head milled 50, 28 25 valves , race ported with 37lbs spring and 1to 1 champion rockers
Fuel pump
Nr racing 285 cam
+0.020 billet rod
Racing spark plug
5.540 chome pushrods
Billet lifters
.038 head gasket
Running on 97
1.Is that ok? Anything different?
2.how do I install rockers and what is the bolt on top of the valves for?
3 . Do I need lash caps? I have them
4. What timming and how to set it if needed
So that about everything and im want to pull 7500 revs on this thanks:thumbsup::cheers2:
Joe-405
Enjoying New Projects
U.S.A.
timing is good............
gotta pic of said bolt on valves ?
Edit..... And if you call NR Racing or ARC their customer service is excellent.
Flyinhillbilly
The great cornholio
North West Arkansas
He's talking about the lash adjusters on the champion rockers. You set your valve lash with the little bolt, and lock it in place with the nut.
matiask1
Santiago,chile
So I did bolt up the studs the furthest they could go and then mounted the rockers and indeed the bolts where the lash but how do I know when the lash is ok? It has to touch the caps with the pushrods mounted? And timming is ok?
Flyinhillbilly
The great cornholio
North West Arkansas
Since you're wanting to turn high rpm's with this, I'd reccomend looking into valve train geometry and how to make sure it's right.
I generally set my lash at zero. Basically tighten them up unti the pushrod just has a tiny bit of drag when you spin it. Make sure you're at TDC on the compression stroke when you make your adjustments too.
---------- Post added at 10:45 AM ---------- Previous post was at 10:44 AM ----------
Btw, your cam card should have a reccomended timing setting on it.
Flyinhillbilly
The great cornholio
North West Arkansas
I'd go with aluminum retainers and split keepers. That requires different cables though. This happened on my clone with lash caps intake and exhaust. The new head will have radius keepers.
matiask1
Santiago,chile
I have aluminum retainers and split keepers but do I need to put this black cap on?
