supermanotorious
Winchmaster 5000
I'm building a 6.5HP winch for a Florida customer. I de-governed the engine and applied a couple "new" concepts to the throttle linkage. I'm very pleased with the "action".
I took one of the swivel wire nuts from the throttle arm and flipped it upside down so it hangs from the bottom of the throttle control
Cut and bent the governor rod so that it connects the butterfly valve to the swivel nut, had to notch the throttle arm plate for clearance
Took the heavier governor spring and connected the throttle arm to a support bracket under the gas tank
The throttle now accelerates smoothly and snaps back to idle when released!
