Predator 212 throttle lever missing; how to connect throttle cable back?
ProvenKey
I purchased a go kart off craigslist around 1 week ago, and now, the throttle cabling tore, a cheap little piece of wiring. I ordered a new heavy duty one, and attached the front. On the back, however, there is no place to attach it to the little throttle column thing(this was where it ripped, I'm not knowlegeable in mechanics). When I look online, there is a whole stainless steel contraption where on my engine, there isn't much at all. What part(s) would i need to replace it and how? Thanks for the help. Here are some pictures. The second picture on the left is upside down, and the air intake is laying there, sorry.
ProvenKey
These are the parts, labeled. also, that spring in the back was connected to the other to provide more tension on the little column, i think.
ProvenKey
this is the picture highlighting the rip in the black part of the carburator column
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Sort of.
The throttle arm thing I posted "should work" the rod well it is just a rod I have used a coat hangar bent into shape.
The thing is a Predator is NOT a clone. hence "should work"
The actual carb throttle shaft "column" as you called it. May or not work, becuase the carbs could be different brands.
Not to worry just call BMI to confirm.
or
Also GoPowerSports.com is a good resource. They sell Predator parts and are VERY helpful on the phone. {(DIYGOKARTS) for 10% off} Sorry to lead you astray Possibly. BMI I just knew had that throttle arm.
ProvenKey
alright man, thanks a lot, ill look into it and call some people. Thanks again.:wai:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
hello? would that be sufficient?
Now don't get too impatient.
There is actually alot more going on there with your engine.
Which is not cool, since you already stated, "I'm not knowlegeable in mechanics"
You see the entire throttle assembly being removed by the previous owner, That leaves to question,
Where are the governor linkages?
obviously removed. but...
Did they fully remove the internal governor mechanics?
only way to know is open up the engine.
If they only disconnected the linkages. Which would be a likely situation being that they did such a crappy job on the throttle linkages.
That means the internal governor linkages are still inside.
However without the governor the engine can now rev to 5500 RPM, and the internal Governor parts are not designed to spin over 3600 and will fly apart inside the engine and destroy it.
So "would that be sufficient" is a huge open ended question.
ProvenKey
How would I be able to check if the internal governor had been removed?
Easy part is check undernieth the tank... Is the gov lever and shaft is present...
More importantly taking off the side cover... And checking is the gov gear and plunger is present...
ProvenKey
So,the lever is actually there. There are still two springs that aren't attached to much. Would I hook those back up to the prospective throttle assembly?
You either need to reconnect the gov linkages or remove the gov altogether; leaving it fitted but disconnected could have dire consequences...
ProvenKey
I got the parts
I got some older engine chunks off a guy, and have all the parts to replace it. I put the carburetor shaft in, but I don't really know how to link up the governor? Whats everything g do? What parts go where? Is there a tutorial?
