Predator 212 rpm issue
And_fis
Ok. So here is my setup. Yerf dog 3202 cart. Comet 30, 60 tooth live axel 14 tooth jack shaft. Predator 212. Std carb gravity fed from tank. Gov removed, arc rod and flywheel. Factory cam. 18 lbs springs. #90 jet on carb. 1" dia exhaust with stage 1 muffler and k&n open air filter. Here is my problem. My tiny tach says I'm only at 3320 rpm max when I'm wide open. I have got good torque. But no high rpm. I max out at 34 mph. What gives? Where is my high rpm? My high mph? Also it's kinda hard to get it pull started. I have checked valve lash and it's .003 on both and my coil is .20 from flywheel can someone help me am I missing something?
I think you're overgeared. If your gearing is too high, the engine hasn't got enough torque to push to it's maximum RPM potential. Gearing down lessens the load making it easier for the engine to spin up. I ran into this on my old kart. I geared down and actually gained top speed because the engine was able to spin up easier.
This has nothing to do with your problems, but you'd probably do well to re-gap your coil to 0.010". 20 thou is pretty wide.
And_fis
Sorry for where I posted this. Thank you guys for the fast response. Let me try regaping that coil. I have the old 10 tooth sprocket for the jack shaft. To put it back to 6:1. Let me see if that does better. Am I wrong or is this kind of setup good to get up to 5500 rpm? I'm just trying to hit 40 or 45 mph. After taking the governer Out, I noticed an increase in torque and power but no increase in top end speed. Would changing the cam fix that issue? Do I need to change to a larger carb? Or, do I possibly need a fuel pump? Just trying to see what would be the next step on this cart.
A cam will help but, there are different profiles for different applications, depending on what you want. Make sure you know & explain to the seller exactly what you want before ordering...
However, change the gearing first! Use the 10t because you have it but, you could probably get away with a 12t, 14t is pushing it ...
A stock setup without the gov is good for around 5krpm so, your setup should be good for at least 6krpm
Have you tried free revving? not that I suggest it for prolonged periods but, what happens when you remove the TC belt & rev the engine?
And_fis
Ok so I regapped the coil to .010 and it starts first pull again also changed the spark plug to .030 then I put the 10 tooth back on so I'm at 6:1... Took it out on flat ground 5 mins ago hit 4200 rpm and was doing like 35 mph. It's also pretty f'n quick on the take off. I have #40 chain almost thought the rear end was going to rip off when I stomped on it. It's a lot better then what it was. but, still not near the rpm range I think it should be. i did free rev it for a few seconds to make sure the chain was aligned and the tach said 4800. I think my 225 pound weight might have something to play in that bit of loss.
And_fis
Mixture? I am running 87 octane. Was running 91 but a friend said it would do a bit better on 87. The manufacture said 87. But as for fuel air mixture I have #90 main jet. And the factory tube above that.
Do a full-throttle run, and cut the ignition with your foot on the floor. Remove plug (careful-HOT) and inspect. The ceramic tip (NOT the electrode) should me a medium tan. White or light means lean, very dark or black is rich. Should be a medium tan to chocolate.
And_fis
It looks like its running a little rich. I pulled the plug out and the piston head is chocolate color. #90 jet is the next step above the factory jet I think. I put the orig. jet back in and it's so lean it won't stay running. So the 90 main jet would stay and I would need a new pilot jet. What would be a good recommendation?
If a #90 is too rich, don't run a #90. This is why I get ticked off when people see a modified engine and immediately suggest a jet orifice size, and it's usually the #90. You have to let an engine tell you it's fuel requirements, not some schmuck with a keyboard in front of him.
Rant out of the way, there are indeed jets available between the factory orifice size, and what you have. I would suggest you grab a couple that are the next few steps smaller than what you have and try them out.
Just to be clear- never mind what the piston crown looked like- you verified mixture with the spark plug nose, right? Please re-read my above post if need be.
89Johnny
Cincinnati, Ohio
I think it's a gearing issue. I run a stock predator on a Clark 420 cart with 9 teeth on the driven and 36 teeth on the axle. Also have the driver spring set to the rear whole In the cover. It accelerates ok but top end is great. I'd would estimate the speed at 45-50 mph but next time I ride ill use my gps to give exact number.
And_fis
Yea the plug is dark at the top. So it's a bit rich. Thank you guys for your help. Let me get a smaller jet and see if that helps.
And_fis
Update: I switched from a 90 down to an 82. It was doing really good except for my top end sounded to sputter a bit and was maybe just a tad bit lean so I switched to an 85 and it sounds alot better. Even at full throttle. No more back fire when I gas it. The plug is pretty dark stil but I think that's from running to rich for too long. I may need to get a new one so I can do a better check. I have a laser temp and the head is running at 356 after 20 min I can get to about 4130 rpm that's it. 18 lbs springs should get me to at least 5000.
And_fis
Ok, so the plug tip looks good now. Changing to an 85# main jet gave me a 200 rpm increase. Still 900 rpm from 5000. I have the stock carb on there. Would changing that up to a 22mm and adding a fuel pump get me to the 5000 rpm mark? Or would that be a waste until I changed the stock cam out? If I change the cam then I need new lifters, rockers, push rods and guild plate correct?
And_fis
Ok, so a few weeks ago I broke the swing arm on my yerf 3203. Go figure it's cheap junk and shotty welds. So I made a new one from 1/4" thick angle that's 2"x2" used the original engine mount, swing arm, axle mounts, and it added about 1 1/2" lift from the axle to the frame. From what it was originally. So I had to make a new #40 chain for the extra space from the axle to the jack shaft. I got everything put on and assembled. It drives and handles better then ever. But, my top speed with 220 pounds of me in it is now down to 31 mph tops. I was hitting 40 mph. So did I loose top end from the longer chain? Would adding a larger then 10 tooth jack shaft sprocket fix this? I really don't want to have to re-fab this Frame to fix this distance issue. Anyone have ideas.
