Predator 212 question
Kyzuuh
Hey guys I'm doing my first kart build and I got a predator 212. I already got an exhaust, intake and bigger jets and emulsion tube.
I have a few questions. first off, how can I tell if the engine is running too rich or lean? I want it to be as close to perfect as possible. Is there any way you can hear it in how it sounds or how it runs?
2nd question, upon starting it I can feel air coming out near the exhaust hole, head gasket area. is that normal? it gets warmer as the engine is running longer but never gets crazy hot so idk if it's an exhaust leak.
KartFab
Dallas, TX
1) Google " how to read a spark plug"
2) the flywheel has fins on it that blow air over the engine. Are you sure it is not just that?
Kyzuuh
It may be, however it seemed somewhat strange to me that I felt the air coming from this one specific place and nowhere else. I'll investigate. thanks for your help. Also, do you normally use some type of gasket sealer on the exhaust?
There is an air duct panel that is in that spot under the bore of the engine.
You can use the original exhaust gasket if it hasn't been torn while removing the stock exhaust muffler.
