Predator 212 non hemi cam difference?
adamjankowski51
Go-no-go gauges, used all the time in the lab and for prototyping. Lab kept at 20degreesC to ensure all equipment and measurements were repeatable, Good old days :)
A go no go gauge should be used at the same temp as the part and is usually a shop floor type measurement. Thermal expansion is the enemy when holding extremely tight tolerance. CMM measuring is normally done at 70 deg F and a part needs to be exposed to that temp for 24hrs depending on size to acclimate ideally.
