Governor removed, low oil sensor removed, new carb with new jets installed along with new carb studs and air filter+adapter, throttle plate installed, cam installed. I am still waiting for my flywheel to be shipped along with my stainless steel valves. I will attempt to make the header, if that fails, I will just buy one (I will probably buy one anyways). I am most likely going to buy new valve guides and retainers to hold the new valves. When the rest of my parts get here, I will install new springs, valves, retainers, guides, connecting rod, and flywheel. Today I went out and bought a complete go kart and will take the 3hp engine off of it and put it in the shopping cart and I will end up putting the predator into the new frame. I feel much safer putting this on a proper frame where the center of gravity is MUCH lower than that of the shopping cart's.
---------- Post added at 01:24 AM ---------- Previous post was at 01:22 AM ----------
That governor C-clip was a pain to get out, but I finally got it after a little playing with it. And I managed to keep the inside of the engine spotless. Both the holes are plugged and sealed with rubber O-rings and lock-tight.
