Hello I’m totally new to this and forums in general. I’ve recently acquired an old dirt bug and I upgraded to a new predator 212 with exhaust and an air kit that came with the jets and were installed as well. I backed out the gov screw and moved the throttle spring to the other hole as I saw in another upgrade video. I’ve also removed the low oil sensor since I thought that was the issue. Problem is is will run great like a bat out of **** for a few at full throttle then it Boggles out and dies once I let off the throttle and it takes a minute to start back up. What could I be missing here? I’ve tried it with the old jets as well and it does the same thing. Any help would be greatly appreciated! Thank you!
