- Messages
- 9,256
- Reaction score
- 4,224
I think you can be fine and dandy with a stock, ungoverned engine relying on valve float to be your rev limiter, but care must be taken to not allow “physics” to bypass these safeguards. Or as Doc Sprocket said:
I bolded a portion for emphasis.
Otherwise, the tendency is to GAS IT and use that gravity to your advantage.
7). IF you are running an otherwise stock, ungoverned engine, is it advisable to avoid excessively free-revving the engine. Use proper gear ratios to keep a bit of a load on the engine at full speed, wide open throttle. Don't try to rev the crap out of the engine with the clutch, chain, or belt off. A load on the engine helps keep harmful vibrations (harmonics) in check. If you have an insanely long, steep downhill stretch in your riding route, back off the throttle going down it. If you hear the valves floating or the engine starting to over-rev, apply some braking force. Coasting too fast can force the engine to spin even faster than valve flutter can prevent.
