Predator 212 flywheel destruction
thisismyusername
Donut Eater
Ok so heres what happened. My friend did a wheelie on the mini bike, he flipped over the back and the bike fell on its side of the pull starter, which dented in, and the flywheel hit it where it dented it and demolished its self. I have it taken off now, and i was thinking about getting one of those nice flywheels that are meant for higher rpms when removing the governor, but they are 100 bucks. Is it worth it to remove the governor and buy one of those flywheels, how much top end speed would be added on really? My gear ratio is 6:1. Also thinking that if i go that rode what are they chances the engine blows up, like how would i blow up the engine without the governor in but with the flywheel, and what other percausions would i need to take, etc. Thanks for any info i can get if anyone else has taken out the governor and replaced the flywheel before, is there anything else needed?
thisismyusername
Donut Eater
Heres pics of the damage
machinist@large
West Michigan, 49331
All your friend wiped out was the plastic fan assembly and the fan housing. Replace those and you're back in business. The main fan backer is in one piece, which has me guessing that the actual flywheel was untouched.
thisismyusername
Donut Eater
Ah yup i see now, where can i get one of these little fan thingy majigers lol.
KartFab
Dallas, TX
eBay, or calling harbor freight. Look in the user manual at harbor freight "predator 212cc parts manual" parts diagram
minibiker
USA
**** just run it as it is I cut off every other fin off all my flywheel fans and they never over heat. These motors were meant to be stationary ( not move) so the fan is there to keep it cool when it is just sitting there . As long as your moving it wont over heat . The billet flywheel will help it rev up a little faster because its lighter. But the best thing about it is that you can build it into a race motor and rev as many rpms as you want to get some real power.
You should know by now which words are on the "banned" list, please don't use them...
Let me just clarify that by "build it into a race motor" he means adding other high performance parts, such as a billet conrod...
minibiker
USA
Sorry I didn't think that was a banworthy word its from the bible. Yes a connecting rod is also needed for higher rpms to make a race motor. The billet flywheel is usually the most expensive part .
JMINDY
Indianapolis, IN
Is it a predator 212 engine? Anyone know if there is a difference in the original plastic fans on a hemi vs non hemi predator engine? I have 2 plastic fans from a non hemi predator engine... PM me your address and you can have one...
thisismyusername
Donut Eater
I got one from my friends predator that he isn't using, and put it all back together and it won't start. :ack2:
It's not turning over at all so I'm assuming it has some thing to do with the kill switch, seems like it's always engaged and wont let the engine start. Yes I plugged in the cords, any ideas?
A piece of flying shrapnel may have moved or damaged the coil; disconnect the low oil sensor & kill switch, then verify you have spark...
True but, how often is it used as a mild profanity? ;)
Remember, we have members as young as 13 here, we don't want to teach them any bad habits...
Poboy kartman
Senior Moments Member
White Settlement Texas
Yeah....I only recently released they mentioned the Poboy in the bible.....something about the "jawbone of an ***"...??....I figure that probably refers to my posts.....
