Panhead5496
Hey guys, just a quick thing I found out the other day.
The screw in rods that extend from the predator 212 that you use to keep the exhaust on can be a pain (well for me at least). I always have issues with the nuts coming off and then the exhaust vibrates, leaks air, etc.
I found a fix if anyone has the same issue or just doesn't like using them.
A M8 x 20 1.25 pitch bolt works fantastic, they are cheap at the local hardware store and you can crank down on them much easier!
Just thought I'd share the info, if everyone already knew this I will feel dumb but hopefully I helped someone!
