Predator 212 exhaust bolt size fix
Panhead5496
Athens, Georgia
Hey guys, just a quick thing I found out the other day.
The screw in rods that extend from the predator 212 that you use to keep the exhaust on can be a pain (well for me at least). I always have issues with the nuts coming off and then the exhaust vibrates, leaks air, etc.
I found a fix if anyone has the same issue or just doesn't like using them.
A M8 x 20 1.25 pitch bolt works fantastic, they are cheap at the local hardware store and you can crank down on them much easier!
Just thought I'd share the info, if everyone already knew this I will feel dumb but hopefully I helped someone! :wai:
Clifton
Illinois
They are studs, many people would prefer to have studs, they should be less prone to stripping out the soft aluminum head than a bolt would be. The nuts need to be torqued down pretty good, same spec as the head bolts (17 ft lb)
I've never had any problems with them coming loose. I suspect maybe yours were undertightened, or possibly you have a long exhaust that vibrates a lot. The solution for that would be to add a brace near the end of the exhaust so that it doesn't vibrate as much.
Panhead5496
Athens, Georgia
Oh. :eek: I have a long pipe, but it is supported vey well on the end.
Studs > Bolts.
:cool: whoops
Lock washers?
I was going to use those, but I did not have enough of the studs sticking out past the exhaust pipe flange to get them to go far enough to lock.
Well this was apparently a failed post...lol :oops:
KartFab
Just as an FYI, the head I was working on the other week had the m8 bolts bottom out at 23 mm into the hole. That’s with a stock gasket and a a 1/4” thick flange don’t wanna have those bottom out before being tight. So I got a 35mm bolt and converted it into a stud on a header I was making.
Panhead5496
Athens, Georgia
I have a 20mm bolt so should be fine.
---------- Post added at 11:05 PM ---------- Previous post was at 11:04 PM ----------
Whoops, just read my first post and I typed 25mm, not sure why I said that. I looked at my receipt from hardware store and they are 20mm!
65ShelbyClone
SoCal
You can also use long set screws as studs and they're easier to remove later with an Allen key.
Another option that avoids replacing them at all is to use all-metal lock nuts.
mrbeggs432
Odessa,TX
I use allen head bolts with lock washers...plus they give more clearance on the exhaust flange versus nuts around the welded area on the header.
Panhead5496
Athens, Georgia
Well, you guys were partly right. The bolts I used luckily didn't strip out, but one managed to vibrate out after I tightened down on it HARD! I have no idea how that happened.
So I went to the hardware store and got some studs and lock nuts. They work great so far, after several hours riding time nothing is even remotely loose so that's great!
KartFab
except for being able to tighten them down with an allen head wrench on performance exhaust :-(
