I'm apologizing aware of some of the threads out there in regards to other Predator builds but I'd like to try and condense the information into one. This post will more than likely only suit my build, but may be a reference for others in the future. With everyone's help we could construct a thread written in the style of "Explain it to me like I'm five" to maybe help others with their future builds.
Without further adieu,
My Goals:
Resources:
For now, that's all I can think of. I'm sure if more comes to mind tomorrow, I'll edit this post
I'm *one* click away from purchasing my engine. I found a discount code online that offers me $24 off! Grand totaling $95.99 for the 6.5hp 212cc.
http://www.harborfreight.com/65-hp-212cc-ohv-horizontal-shaft-gas-engine-epa-69730.html
My Goals:
- Build a Predator motor capable of 50mph or greater
- Have a reasonable amount of low end torque, without suffering completely at the top end
- Reliability and longevity being a key factor (This should have been first)
- Learn as much as I can about "building" these motors
- Valve lash. How to set it. The importance of it.
Google's definition of Valve lash-This is the clearance between the base circle of the camshaft lobe and the camshaft follower or tappet. - Jackshafts (What they look like and how they work)
- Will my Comet Tav 2 Torque Converter be interchangeable with the new Predator 212 set up? If not, what else would I need
- Determining the length/type of the chain I might need if the motor doesn't mount in the exact same position as my original.
- Belts (How much play is too much play? What is the proper amount of play on a belt)
- Would removing the governor be detrimental to my engine if I plan to be wide open throttle 3/4 of the time. (This Kart will be built as a toy and mostly pavement driven)
- Will my current brakes set up be sufficient enough to stop the kart with this new motor? (I'm currently using a manual caliper/disc set up)
- How to choose which cam is the RIGHT camshaft for the performance increases Im looking for.
Resources:
- www.harborfreight.com
- http://www.kartpartsdepot.com/
- http://www.ombwarehouse.com/
- http://www.smallenginecams.com/
- http://www.gokartsupply.com/tcbelts.htm
- How to Clean your Torque Converter (will add link later)
