Predator 212 Electric Start
mikeskinner
Hello Guys, I've lurked around here a couple weeks and picked up some very good info. My grand kids, girl 7 & boy 8, just recently got a Fox Hornet that's a few years old. Seems to be in pretty good shape. Robin engine 6 hp. runs good and starts on first pull everytime but leaks gas like a b. We got the cart for a good price because the guy who had it couldn't deal with the carb issues. After putting $10.00 worth of gaskets on it, I don't want to either so I'm putting the robin on craigslist. Today I went to HF and bought a Predator 212 and myself, my son, and grand kids are going to swap them out tomorrow. Armed with info I found on posts here I knew to get the 60363. Thanks. Any tips from anyone doing this swap before would be appreciated. I'm also thinking of taking a starter off a old toro mower and see if I can make it work. Anyone ever do this??? One interesting thing about the 212. The pic on the box shows the pull cord handle at the back but in reality it is in front. I assume it would be just like a lawnmower and just take it off and turn it 180. Great forum
Thanks
Mike
Not gonna happen, there's no teeth on the flywheels. :censored: Also there's no electric start kit to fit those engines that we know of.
:feedtroll:
I'm not sure...
The older predators at least can fit a Honda flywheel as far as I know..
that's available with cog for a starter kit.
Not sure you have the mounting tabs to mount the starter, but you're half way there already..
downside: the starter kit is more expensive than a predator on it's own... so not the best idea ever I'm afraid.
And since you just bought your predator, chances are the Honda flywheel will not fit anyways....
and we're back on square one (aka NO!)
Las Vegas
My opinion is you won't need one, these engines start easier than any pull start I've seen. My 212 started on the first pull in winter with the choke off and my 9 year old has no problems cranking it.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Yup. My Girls 9 and 14 can pull start there predators too. Besides with electric start if the starter button is in the drivers area now you need a choke control cable too.
Just not worth it or necesary
mikeskinner
OK I'm gonna forget the electric start. We swapped them out today. 45 minutes to swap them. They both had same mounting holes. One thing was the oil filler on the back of the engine would not let us slide it back to align the holes. Talked about putting a plug in it and then I got a brain fart and took it to my grinder and ground the finger hold off. Worked great. Then it took us about an hour to figure out a reliable throttle set-up. Made up a bracket and hooked a STRONG spring and it worked fine. Initial run it would only go 15 MPH (GPS). Put my big brain to work and noticed that when we had WOT there was a stop and it was adjustable. Turned out a few rounds and next run was 29.5. Ran out of time and energy (97 degrees here today) but I think it will open up a little more. It was such an easy swap I regret not taking photos to post.
I do appreciate the great advice that I got here.
Thanks
Mike
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Cool sounds like fun and also all the little adjustments are standard things we see around here. Post up a pic of the kart anyway we love to see what people have.:thumbsup:
