Predator 212 dies at full throttle
Boodlebug21202
I just recently built predator 212cc db30 and I'm having an issue with my engine. It idles just fine but I can only do 3/4 throttle or elst it dies after i go full and it won't start back up for a while. I've checked my spark plug and wire just to make sure but there just fine, it's a brand new stock carb with stock air filter but no governor. if anyone can help me please do I've been trying to get this thing running for 3 months.
Boodlebug21202
I'm pretty sure I just an external removal, I bought the engine with out it and It worked just fine when I got it. The throttle linkage looks gehtto but it work perfectly fine
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
The first thing that I would do is order a new side cover gasket and go inside the engine and remove that arm for the governor. You can then put a paper towel in there and tap the hole to put a bolt in it. I highly recommend removing that because if that pin comes out there's a good chance that you'll need a new engine. You will need to clean the engine thoroughly with carburetor cleaner to remove any shavings left behind.
Second I would rig up a throttle linkage like the ones used by red beards garage.
As shown in this video:https://www.youtube.com/watch?v=STNiG8sIQLg
This is done on a GX200 which uses the same throttle setup as the 212s. And if you don't have the throttle setup from factory i would invest in a top plate or half top plate. Both come with a throttle linkage and the extremely important return spring. I say extremely important because the last thing that you want is to have your throttle cable stick at full throttle.
And when you say that the carburetor is a new stock one do you mean that you bought it brand new or the person you bought it from said that it is brand new.
Also I noticed that you have a header pipe. Do you also have a performance air filter or are you using the stock intake? If you are using a stock carb jet with a performance air filter and a header pipe the engine will be running to lean and you will need to use a carburetor drill set to drill it out some. Or you can order a drilled jet online.
The drilled main jet can be found here:https://www.gopowersports.com/clone-carburetor-drilled-main-jet-predator-212cc/
Use the .38 jet
The side cover gasket can be found here:https://www.gopowersports.com/side-cover-gasket-012/
And the top plate can be found here:https://www.gopowersports.com/top-plate-for-212cc-non-hemi-predator/
This is for a non hemi which based on the valve cover is what you have.
