Predator 212 Build Questions
Scotfree1993
Long Island, NY
So, finally starting my barstool build. Have order all the parts for my engine and plan to bulld this first so I can choice and or modify my bar stool to fit the engine.
Ordered: Billet FW, Billet Rod, MOd2 Cam, 18lb springs, adjustable carb, jet kit, air filter, exhaust, eginge plate, fuel pump and gas lines.
My question is should I use a clutch or a torque converter? Secondly should I be concerned about HP limits with either?
Staff Murderator
Torque converters are typically used on off-road karts to allow the kart/buggy to traverse hills--more torque and a low gear ratio for climbing; higher gear for flats and straightaways.
A centripetal clutch handles road and flat ground well and is also very simple.
Depends on what you want. Have you drawn inspiration from other barstool builds? What did they use?
Scotfree1993
Long Island, NY
A lot use a torque converter. However I need to find someone that has modified the engine too.
Staff Murderator
Most torque converters (they're really a CVT--Continuously Variable Transmission) are grouped by max horsepower ratings and given a series number, a la 20, 30, 40 etc.
They're also a bit bulky and add some somewhat considerable weight.
