OK. Got a Comet 30 TAV2 knockoff (asymmetrical belt) for the Manco Dingo I've been working on. Not totally impressed with the fit of this unit to the engine.
Main issue is alignment of drive pulley to driven pulley. The drive pulley is ~1/4" inboard (towards engine) closer than it should be. After monkeying with it in the summer S FL sun, I said close enough and ran it like that. Didn't immediately explode... Is 1/4" close enough? Or should I washer it out a bit?
Other issue is that the engine shaft is too short... by 1/2" or so. From the reading I did, this is a known issue on this combination. I left the gap and torqued it to spec with a long bolt and suspect it will be fine. That said, addressing the issue above makes this one worse.
Thoughts please. Thanks.
