Predator 212 and Bullet Lines TC
crispycritter47
McAlester, OK
I have a Manco Hyper kart that I'm "rescuing" (for lack of a better term). I have replaced the Subaru Robin engine with a new Predator 212. And, I bought this TC from Amazon - "Bullet Lines ✮ Torque Converter Go Kart Clutch, Replaces Comet TAV2 3/4 inch 30-75, Manco, 10t 40 or 41 chain, small engine belt drive, 3/4" 218353A, (0.75" 10T 40/41)".
This is what I was told by the seller:
"The predator motor has a shoulder at the crankshaft that sits about 1/8 inch lower than other Honda or clone engines, and if you do not provide the right spacer, then the driver will rub on the back plate. Also, you will need the correct anti vibration pilot washer that is not included with this kit. You will need 5/16" -24 screws, 1/8" x 1 1/8" OD washer, and the correct balanced pilot washer."
I know I can get the screws and the 1/8" washer at the hardware store, but not sure about the "balanced pilot washer". Is it actually needed to make this TC work with the Predator?
Any help will be much appreciated!
tazmannusa
Yettem, California
Not sure what they mean by balance washer , I am running a similar one if not the same one on one buggy. in the link to amazon in the lower right of picture shows the stepped pilot washer that goes on the outside end of the driven, the 5/16 bolt goes through it using a lock and flat washer, with the correct spacing on the backside that's about it as far as I know and that is what I have used on two different predator setups, I also have a GTC back plate setup and it mounts the same
crispycritter47
McAlester, OK
Thanks, tazmannusa. I thought was the case, from what I've read on here, but just wasn't sure.
I think the seller may have been trying to sell me his higher priced TC.
I'll give it a go when it gets here (hopefully tomorrow), and let.you know how it goes.
Thanks again!
