Predator 212 Air Filter
cOw
Raleigh, NC
Right now my Predator 212 has the stock air box. It has a hose running to the top of the fuel tank, and one leading into the cylinder head. I have now bought a K&N cone air filter and an adapter to fit it to the engine.
What do I do with these two tubes that are no longer used, and what are they for?
Thanks
tundrabeagle3
Ca
the one coming from the gas tank is a vent and can be folded up or have a small air filter installed, the tube coming from the valve cover can be left hanging or have a small filter installed on the end of it.
tundrabeagle3
Ca
Unless I'm mistake, they're both breathers. Put a fuel filter in the end of them & you should be good to go
that is correct. fuel filters are a good idea since they are cheaper than the small air filters sold at auto part stores.
cOw
Raleigh, NC
Where would I these fuel filters? Are the nessecary to have something on, or can I just leave them off?
Tundrabeagle, what do you mean by "folded up" in Post #2?
Cheapo, plastic, inline, automotive fuel filters for carbureted engines. 'Bout $2 at your local auto parts store. And yes- you want them there to keep dirt out of places that should not have dirt in 'em.
Yep, that'll do it :thumbsup:
Do I leave the hoses hanging out with the filters in them? or should I remove them and place the filters directly into the spot where the hoses were?
Being that the filters fit to a hose, leave the hoses in place. You can shorten or lengthen them to get them out of the way...
IMHO, I would route some hose to a remote location and plug in those fuel filters and tie them cleanly to something out of the way. If it were mine, I would get ultra fancy and use vacuum line tees to route all vent lines into one single hose, and mount the filter inside of the blower housing all neat and tidy and out of sight. But thats just me.
As the hoses are different sizes, you may have fun finding a T that fits both.
tundrabeagle3
Ca
I run my bike offroad all the time and have never had any problems except for oil shooting out of tube on the valve cover ( second pic) sometimes.
fowler
Bullsbrook West Aus
u realy need a filter on that hose
leaving that hose open is worse than having no intake filter as it is the breather for the whole engine which means any where air can get in the engine dirt can get
remove the rocker cover and u may find that area full of dust causing severe internal damage
u can leave the fuel tank one open but then u need a fuel filter
u cant fold it over as then the tank wont breate and the engine wont get enough fuel
i do like the fuel filter idea its a great idea
I would say get a vented fuel cap and block the fuel hose, Put a mini filter on the valve cover vent. Am I wrong?
Not as hard as you may think. Automotive vacuum hose tees are available with different sizes on the same tee, and I have even seen some that have stepped down ends that you cut at the right size. In fact, I think I have one. EDIT- Pic added, see below.
That said, I would not tee them together. The only thing worse than oil in your gas is gas in your oil.
cOw
Raleigh, NC
The filters that I bought both look like this (pic attached)
Do I literally just shove one end in the hose, and then leave them?
I feel like they will flop around a lot, so maybe secure with tape or something?
That filter will do the job. Tie it to something to stop it flapping around
