predator 212 6.5hp engine Electric start?
Jacksondpope
I have a go car with a predator 212 6.5hp engine and I would like to know if I can put a electric starter on it. Thank you
If you have a Hemi 212cc. 60363
It has the same taper as a Kohler 270 flywheel.
It is expensive to do the conversion.
Jacksondpope
http://www.bonanza.com/listings/Ele...mvXSIDHIoDbemvhnu06njybpu63kXMVDSwaAqJJ8P8HAQ
well you can but i dont see why...
is it hard to pull or something?
The go kart goes once it is started so I can't start it get in and go I need someone to help hold it or I need to hold it while trying to get in and I have tried that multiple times and failed. (Go kart almost hit another at with no driver) so I need a eclectic starter or I need to fix something on it.
---------- Post added at 03:47 PM ---------- Previous post was at 03:45 PM ----------
But thank you for the responses
aham2003
Cleveland, Tn
Have you tried lowering the idle screw?
A wheel chock is the immediate, easy remedy. They make portable ones now. :D
Gbag
New Jersey
Make sure your throttle cable is not too tight. Mine was so it rolled when i started it. Just loosen the cable to make sure the throttle arm returns completely.
