Pred 212 Proper Gearing & Clutch Installation
NDBell
Hi, first post here and I have a few questions.
I'm attempting to build a drift trike and I've run into a couple of minor problems. First, I'm not sure if I'm installing my clutch properly. I've test ridden the thing a couple of times (5 mins in total) and every time the bolt that holds the clutch to the shaft comes loose. I bought a shorter bolt so I wouldn't have to stack washers (which was most likely my problem). However, I'm still unsure about how to install the clutch properly.
The engine came with a decently long key, so long that the clutch hung off of the shaft more than I was comfortable with. The clutch came with a much smaller key, and using it, the clutch is nearly completly on the shaft. Here's what I'm confused about- should the bolt/washer touch the clutch or the shaft? Right now the washer is decently tight on the clutch and it seems to do fine - just want to make sure that's the proper way to do it.
Also, I've got a 54 tooth sprocket, a 10 tooth clutch, and 12 inch tires, which gives a 5.4:1 ratio. I'm assuming this is ok?
This is my first build, so I'm a huge noob. Sorry for the long post and thanks for the help!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
The gearing sounds Fine. Maybe could be a little lower, just for Drifting purposes.
But "It'll Be fine"
NDBell
I rode it around for 10 or 15 mins and everything seems great! I cannot believe how powerful that little predator engine is. I think the engine is idled too high, because when idling the clutch seems to want to engage and it makes an awful scratch sound. Super excited about it!
I love a happy ending. Which reminds me.....
I should schedule a massage.:roflol:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Sometimes clutches will make kind of a scratchy swishing sound, other times ring like a bell.
If the idle was to high it would be trying to drive away under idle.
Can we get a pic of this Machine? Please, Just for fun.
NDBell
https://imgur.com/a/mlqma
That's what I've been able to put together so far. My original plan was to put the engine in front of the axle, but that ended up not happening so now I have a super long frame (might cut it back later). Still needs pegs, seat, paint, pipes for wheels, etc but it's coming along!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That looks Cool. Actually for Drifting having the engine behind the Axle is a good thing.
Like Swinging a String with a Rock tied to the other end. it helps create Centrifugal force.:thumbsup:
