Hi, first post here and I have a few questions.
I'm attempting to build a drift trike and I've run into a couple of minor problems. First, I'm not sure if I'm installing my clutch properly. I've test ridden the thing a couple of times (5 mins in total) and every time the bolt that holds the clutch to the shaft comes loose. I bought a shorter bolt so I wouldn't have to stack washers (which was most likely my problem). However, I'm still unsure about how to install the clutch properly.
The engine came with a decently long key, so long that the clutch hung off of the shaft more than I was comfortable with. The clutch came with a much smaller key, and using it, the clutch is nearly completly on the shaft. Here's what I'm confused about- should the bolt/washer touch the clutch or the shaft? Right now the washer is decently tight on the clutch and it seems to do fine - just want to make sure that's the proper way to do it.
Also, I've got a 54 tooth sprocket, a 10 tooth clutch, and 12 inch tires, which gives a 5.4:1 ratio. I'm assuming this is ok?
This is my first build, so I'm a huge noob. Sorry for the long post and thanks for the help!
