dcastillo
Question, On my bigger gokart I used a mechanical Estop instead of a contactor to connect the Battery to the controller. Per the wiring diagram I installed a 1K precharge resistor across the EStop. If I understand correctly, the purpose is to prevent the large inrush current from the caps in the controller right?
My question is on my smaller 350Watt controller Im installing now I see no indication that I shoudl add one, but when I connect the battery to the controller I get a nice spark/arc which I assume is the Caps charging.... Should I add one to the smaller controller as well?
If it makes a difference, the controller has a two wire harness to connect the batteries to, I was going to break the 24V side with a 30A mechanical switch, should I just put the resistor across the terminals of the switch so when the switch is open, theres actually a 1K load to allow the caps to precharge?
thanx
Danny
thanx
Danny
