So I played around with the governor a bit.
AS IT WAS....
(not running)
I could not see anyway how the carb would open up all the way. 3/4 of full throttle maybe.
With only the solid rod connecting the gov. arm to the carb (spring disconnected), the butterfly WILL close all the way. With the rod and spring connected, even with the throttle lever in the idle position, the spring pulls the butterfly open about 1/4 of the way.
SO I ADJUSTED THE GOVERNOR ARM....
I loosened the nut that holds the gov. arm to the part of the gov. that extends down into the block (GOV. SHAFT). I rotated the gov. arm so that the butterfly opened all the way. Then I rotated the gov. shaft in the same direction I rotated the arm to open the butterfly, and then tightened the nut back up.
AS IT IS NOW....
Moving the throttle lever WILL open the butterfly all the way.
Allowing the throttle lever to return to idle will close the butterfly completely IF THE SPRING IS DISCONNECTED AND ONLY THE SOLID ROD IS CONNECTING THE GOV. ARM TO THE CARB.
IF THE SOLID ROD AND SPRING ARE CONNECTED, then the spring still pulls the butterfly open 1/4 of full throttle when the throttle lever is in the idle position and the engine is not running.
SO MY QUESTIONS ARE ...
DOES THIS SOUND CORRECT????
HOW DOES THE BUTTERFLY EVER CLOSE ALL THE WAY???
IS THAT SPRING NEEDED??????????
