New shopping list is pretty similar to old one.
So this is what I am going to do......
$140 4.45" Billet Connecting Rod
$45 90mm Flat Top Piston (Cut to be flush with the deck - around 0.017" I think)
$135 Dynocams 308 Grind (Advanced 6 Degrees) 0.308" Lift. 245* duration for 6k
$45 SS Valves
$18 Retaiers/Keepers
$25 Valve Job
$30 Mill Head (0.035") for 10.75 : 1 Static Compression Ratio
$FREE Port And Polish (done by me)
$20 HD Springs
$8 Advanced Timing Key
$28 Cr - Mo Pushrods
$88 Robertson Torque Tube H-Loop
$108 32mm Ebay Carbs with Adapter, Jet Kits, Filter, Silicone Hose
$170 420cc Engine
______________________________________________
$860
Bit more than the VC 460 and less displacement with weaker block, but included
carb adapter, carb, low jet kit, main jet kit, filter, silicon hose, ($110) and exhaust ($90), SS Valves ($43), More lift Camshaft, Flat top Piston, More Compression......
Should have good torque, broad powerband, and spin near 6000 RPM.
I might not need the SS Valves but figured they can't hurt.
$45 SS Valves
$25 Valve Job
$20 HD Springs
$170 420cc Engine
$860
