Powerland 420 advance timing
Staff Murderator
Just lap the flywheel to the crankshaft and you can put the timing wherever you desire. No key needed!
According to the NR site, the same key works for the little guys and the big ones.
http://www.nrracing.com/product-p/nrkey.htm
Key, Timing, Offset, GX Hondas, 6.5 to 15 hp Chinese OHV, & Predator
GX200, 6.5 Chinese OHVs, and 212 Predators
2 Degrees - Recommended Raceseng or Dyno PVL flywheels
4 Degrees - Recommended for use in GX160s on Gas and GX200s using Aluminum or GX160 Flywheels
8 Degrees - Recommended for use in GX200s on Gas and 160s on Alky with stock flywheels
12 Degrees - Recommended for use in GX200s on Alky with stock flywheels
GX270 & GX390s (will provides approx 2 to 3 more degrees than shown)
6 Degrees - Gas Applications with ARC or Stock Flywheels
8 Degrees - Alky Applications
Another link for a key.
http://www.vegascarts.com/product-p/tkey.htm
