power supply
Bluffer
Hello all
I have a damaged scooter with a hub motor, controller and throttle. No batteries. I would like to test the system with a power supply before I spend the cash on batteries.
Can anyone recommend a source for a 48v 10amp power supply? Is this something that could be salvaged from some other device?
Thanks very much
Andrew
DCProductions
Cockney Ragamuffin
Louisiana, USA
I think a power supply that large would be very expensive, especially for a test. You could potentially use 4 car batteries in series; that should supply plenty of amps at 48 volts, though it could be difficult to find that many people willing to lend you their cars.
anderkart
Surprise Arizona USA
Try hooking it up to a 12v. car battery with jumper cables.
If it runs but just slowly, you can be assured It'll run a lot faster at 48-volts.
Bluffer
Thanks
Thanks for the replays, Im I correct in thinking the controller will require 48volts?
anderkart
I've never tried but I'm pretty sure a 48-v controller would still work off of 12 volts.
Say your scooter had 4 x 12 volt batteries connected in series. (=48-v) And say you rode around until those 4 battery's were almost completely discharged, and the scooter was really slow. At that point you would probably be operating your controller at only around 12-volts. Your controller would probably still keep functioning until the battery's were completely dead reading 0-volts under a load.
So... the 48-v controller should work just fine off a fully charged 12 volt battery. I think the motor will just turn slower than it would @ 48v.
I cant think of any reason it would damage the controller to at least try this, it would basically be just like running off a nearly dead 48v battery, except the charged 12 volt battery would have more available amperage.
