Power band?
kendelrk
redneck engineer
westland michigan
dosent even look like your pushing the throttle on the Tec, ive been through 2 Tec's 2 clones and a briggs, my tec on bike sucked, the tec on my kart, acted bad, all the time, i lost a clone, but my new clone has had some carb problems so yeah, but by far my briggs has had the best power band i have ever had, when i hit the throttle its ready, i think the tec would have a better powerband tho
Bluethunder3320
you get more punch if you stretch out the silver spring on the clone throttle with 2 fingers.
but thats just messing with the governor linkage.
i think it all comes down to torque. look up the ratings for each.
Russ2251
AZUSA:Powered by LAWN-BOY
since the tecumseh is built for go karts wouldnt it have a better power band?
This isn't really true.
This engine powers many types of equipment including gen sets, pumps, snowthrowers, etc.
Bolt for bolt, piston piston, head for head... there is no difference.
The PTO configuration or throttle/governor setup is what makes it different from the other engines only.
The Yamaha KT-100 is an example of a kart specific engine. There are others such as Parilla.
B man
Tecumseh FTW!
Oliver springs,Tn
that's what i thought. but i have also seen them called enduro. i didn't know if it was different.
But how would you determine power band?
r97
Measure twice cut once
Massachusetts, USA
Some companies (Honda) post their data. Most do not, at least not from what I've seen.
Robin Subaru, ;)
