Yeah, worse case, buy a cheap used 10/22 that's beat up and just use the use the receiver and whatever else is good and build it they way you want it.
I paid $170 for one, basic grey synthetic stock with dovetail scope mount and no sights. Built it up from there.
They make a 25 round mag that works flawlessly. Have even higher capacity but reliability can very after 25.
Yea, I’ll just stick with the old tube fed Marlin or my Remington. And not have to screw with a clip and reloading it. I can reload a tube in about a minute.
I ended up polishing the bolt and inner portion of the receiver on my tube fed Marlin Model 60 and it made a big improvement on the action.
Looks like that one is a pain to mod. It's a drop in trigger group and finicky, apparently. Unfortunately there are no aftermarket trigger upgrades and not many parts available. You got an eye for modding, so I would look for a decent used trigger group and try and mod it. I would just deal with it, since in sounds like it is normal, but that 5-6lb trigger pull is awful. lol. If you can figure it out and some way to ease the pull, a YT video would probably go viral. 😂
I'm going to try a little sanding on the sear. More polishing than removing, but we'll see how that goes.
Could also be a spring that could be clipped a few turns.
Haven't gotten into that yet.
That's what I would do, but I'd find a used group to mess around with and keep the original the way it is. Sounds like the original is exactly the way it should be, and parts are becoming hard to find since no aftermarket.
The valve lapping compound is a lot quicker. Only have to cycle it a dozen times or so. My great uncle Joe taught me that trick when I was about 5.
IMO the expensive high dollar firearms are all matched upper and lower receivers, machined almost perfect and carry a premium price tag. Some simple elbow grease and time working these parts (polishing, compounds, toothpaste etc.......) turn these average affordable firearms into buttery smooth accurate tack drivers.
Sparkwizard
Richlands ,NC USA
For anyone building a budget custom Ruger 10/22, you should check out S&P Outfitters. They buy new rifles from Ruger, strip them and build custom rifles for "clients". They sell the new takeoff parts at reasonable prices. My 12 year old son and I bought two recievers from them, he got a youth size pasticc Ceracoated red white and blue stock, 16.5 inch blued barrel with fiberoptic sights and a BX trigger assembly. I got a heavy taper 20 inch stainless barrel and a walnut Deluxe Sporter stock, used a trigger I already had, and we spent about 420 total. We got new bolt assemblies from them, also.
Sparkwizard
Richlands ,NC USA
For fine grinding inside the receiver, toothpaste is too fine, valve compound works fast, but is pretty agressive. I have used Brasso metal polish liquid for many years. Just pour it in, operate the action/dry fire. Obviously, clean well after you are happy with the results.
This is great! I was unaware of this company. Between them and Kidd Innovations you could build a hell of a 10/22 for the fraction of a new one. Thanks for sharing.
FYI: Be careful dry firing a 10/22. The only weakness in one is the firing pin, depending if you got a good one or not. It's a real toss up if you got a good one or not.
