Ibnzmonkey
Keep Austin Weird
The Comet 40 does not use a backplate. And you definitely do NOT want to use two CVT's. They'd be constantly fighting each other, as it would be impossible to perfectly sync both engines' RPM at all times.
IMHO- The best idea is the original one. Two engines synched 180* off each other, connected by chain to a single jackshaft. The output of the jackshaft would have a clutch (or CVT for that matter), feeding the axle.
Interesting. You may be correct, for dual CVT's to work correctly, you would need both engines turning the EXACT same RPM with the same loading.
I like the original idea too. I may go with that when the time comes. Now I just need to shop around for good prices on those 420cc engines. I see that the Lifan is rated at 15hp, the Predator at 13. Is the extra 2hp to start off with really worth it?
Mods will be minimal but include.
Uni-filter
Candy Cane header
.350 lift cam
55lb Valve springs
.925" Bored Stock Carb
Governor removal
(all parts from AGK) I think I can get a reliable 20hp from each engine with those installed. I will be removing as much unnecessary parts from the engines as possible to lose weight. Those engines weigh like 65lbs each...
yeah....
that would be sweet to have that much torque with something that has tracks. especially if it has a shift able transmission.
would be a blast in the mud!
