Possible mod or retrofit needed for TC's?
Bbqjoe
Banned
Location, Location
Is anyone else uncomfortable with how little the connection is between the engine shaft and the driver?
I haven't had any problems, nor have I heard of any, but it sure seems as people improve horse power and torque on their engines that we're asking an awful lot out of that 1/4 inch or so.
Other than finding a way to extend the shaft, I'm uncertain what else might be possible.
Any ideas?
the majority of the 'rotational' force is carried by the key only..
and as long as you find a way to support the key (to prevent it from bending/breaking/shearing)
I see no reason why a plain simple extension isn't up for the task.
Where it get's fishy is indeed the linear forces (applied by the belt) that is in fact trying to move the driver closer to the driven unit.
as long as the spring in the driven is weaker it'll give first, but there will be stress on the hollow shaft of the driver at least.
unfortunately proper shaft extension is the ONLY way to prevent that really..
ideally a keyed 3/4 straight shaft (just as the engine shaft) sitting flush with the latter drilled and tightened up against the engine shaft. with the key spanning both the original and the extension
All lateral forces are then on the bolt (which itself is supported by the hollow shaft of the clutch/driver)
I doubt you'll be able to shear such setup to be honest.
Maybe with a sledge hammer but most likely not with a TC belt.
but I totally agree that this looks terrifying and that the length of the shaft is lousy at times
(some engines worse than others.. but even org Hondas nowadays come with rather short shafts)
So if you're in need.. find a keyed shaft (matching your engine of course) chop off the desired length and drill through... clean the cutting faces nicely and you have all the extension you'll need imho.
It seems to work for all normal purposes. Otherwise there would be another way to do it.
If your really trying to push the ponies through the little TC's. Get some keyways machined in your shafts. 2 keys would be twice as strong.
Bbqjoe
Banned
Location, Location
Thank you.
Bbqjoe
Banned
Location, Location
I would feel ever so much better if the splined hub fit all the way over the shaft.
A shaft extension could be nice, but then again a whole lot is riding on that 5/16ths bolt.
Joe-405
Enjoying New Projects
U.S.A.
I prefer all hardened parts also as it lasts longer and goes in farther.
well joe... a 5/16th bolt is much tougher than you'd think in this application,
keep in mind that there is very little to no shearing force involved, thank to the shaft faces (nicely touching) most if not all is converted to the extension trying to pull the bolt out instead.
(over a small leverage anchor though)
Anyways.. unless the bolt is made of cheese, I don't see you pulling out an 3/16" bolt by hand ;)
and that I say because you can apply MUCH more torque with your hand than what the kart is propelled by.
Bbqjoe
Banned
Location, Location
This is all good to know.
And I'll just keep on keeping on with how things are.
Just knowing myself though, if I had designed the TC, there's no way I could sleep at night relying on that 1/4 inch.
nono...the other way around...
the engine shafts got shorter over time ..
take an old flathead briggs, or a GX from the eighties and you know what I mean...
the TC design is older than the short shafts ;)
MrC.
florida
Here's something to kick around, since so many guys claim 15 to 18hp from a 6.5 3/4 shaft 212's, why not turn down a 1 inch shaft on a 420 then run the cheaper 3/4 30 series TAV with backing plate. has it been done? can it be done, should it be done? precutting the keyway would be the biggest hurtle.
Just a thought
MrC.
Poboy kartman
Senior Moments Member
White Settlement Texas
Just a thought
MrC.
Costs more than the TC upgrade.
Bbqjoe
Banned
Location, Location
Those bastidges!
Did someone ask for shorter shafts, or is the man oppressing us?
hmm..
let's say there's no need for a longer shaft to mount a belt pulley or anything related to industrial applications really..
the ONLY need for a longer shaft is a cent clutch or TC...
And since they're industrial engines, and a shorter shaft means less material, thus production costs... (they save a penny per engine maybe... but over the years that adds up enough to bother us with such dilemmas)
what can I say *shrugs*
most mfgs do not have karting applications in mind obviously :(
cavfire
auburn, georgia
Just a thought
MrC.
The 30 series is available in 1" for the driver already. No need to turn down the shaft on a 420. Torque of the 420 would be more of the issue though.
