Poor Man's Shifter Kart: Engine Choice?
Blackdog
Burlington, Vermont
Assuming i could find a CR125 or a CR250 engine used, for reasonable money ($500 or less)...which would be a better option for some fast fun...not looking for race class compliance. Is the 125 too finicky with narrow power band? Would the 250 be easier to just run stock? Is a early 2000s engine significantly better than an earlier 1995 engine ?
Thanks. I know it's a lot of questions... trying to wrap my head around which direction to pursue.
Are you positive you want a 2 stroke engine? Doing so you'll need to have a tuner pipe (expansion chamber) custom made for the kart. It would not be an easy task. A CRF125 (4 stroke) will be a lot easier to get hooked up. Just my opinion. If you go the 2 stroke route, find someone who makes tuner pipes for engines, there's a lot of math that goes into it. They can be setup for bottom, middle, and top end power.
Blackdog
Burlington, Vermont
Jeez...i never knew that. So you'd need to reuse the bike exhaust/muffler or have a custom one made...hmmmm....there are not off-the-shelf pipes for this motor?
---------- Post added at 09:03 PM ---------- Previous post was at 08:58 PM ----------
Okay...so switching gears to a four-stroke (no pun intended)...is a CRF250 a reasonable candidate?
You can run a 2 stroke without the pipe, but it'll be down on power. A CRF250 should be fine, just not sure you need anything that large realistically.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Dwebb26
Indiana
Hey man can you help me out with wiring for that exact Lifan
Engine. I’m goin for the same thing.
Dwebb26
Indiana
Could you offer me any help to wire up a kickstart
Cdi Lifan engine? I made a post about it but no response
