polaris XCR 700
Jeremiah
Picked up one of these, just rebuilt with a performance rebuild kit, doesn't come with clutch but it was $250. Now I need to know what kind of clutch/torque converter to put on it. Any Ideas?
Jeremiah
yes its keyed with threaded bore. I think I'm going to use a ford f150 torque converter instead of finding a new clutch. If the engine idles at 1500 rpm would a 2600 rpm stall on the torque converter work?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
ok that makes sense..... dont they just have regular keyed shafts?? i was looking at a polaris 340 a while ago and it just had a reguar keyed 3/4 shaft. if so then find out what size shaft you have and then just get a normal tc like a comet 40 series. i think that would work, and if not look around on ebay im sure another polaris clutch will fit it....
redsox985
PA
Maybe give CVTech a call. They seem to make some heavy duty stuff.
HellSpawn
Wadena, Minnesota
It WILL have a tapered shaft, so you WILL need to find a sled clutch. If you want to save yourself the time and possibly a little bit of money, You could probably just fit another clutch that is set up for another motor and fine-tune it with new weights/springs.
bighead
Pacific Northwest USA
You need the original engines clutch. And the Original driven clutch. Or ones to mix and match.
I think a lot of sled engines are 30mm tapered shaft. Ebay 30mm sled/snowmobile clutch.
Here is one for About $34 shipped. Conform you have a 30mm tapered shaft though. Then look for a driven clutch that take the same sime top belt width that the clutch you get.
Also the Honda FL250 driven is 30mm but uses a much smaller belt than the sleds use.
http://cgi.ebay.com/ebaymotors/Good...70619320QQptZSnowmobileQ5fPartsQ5fAccessories
Jeremiah
Does this engine require a CDI to create ignition? Or can I run the coil primaries to the correct stator outputs?
Jeremiah
That's no big deal, found some for 50 bucks on ebay. Things are coming together with my project. all that's left is the CDI and a clutch. Going to use a transaxle for forward and reverse, if it breaks it breaks ill put something better in but for now it will do. Found a local ATV/Snowmobile junkyard to turns out the owner is a friend of the husband who married one of my friends so I got the hookup there. I'll make a thread when I start fab'ing up my frame and drive line.
One more question:
Will this CDI work? http://cgi.ebay.com/Polaris-xcr-800...wmobile_Parts_Accessories&hash=item5199855767
and I dont see 3 connections from the box for the 3 coil positives. How do I connect this to the coils to produce ignition?
Jeremiah
might be able to get one through a dealer otherwise used they are very rare I've found
