I have a kart I just picked up with a no start. Wiring has been hacked , ignition broke, etc. Just replaced the ignition and rewired... kart turns over but has no spark. I need to verify the wiring to the control unit which then goes to the mag to be sure itss wired correctly... Its a 6 wire, colors include , red, red/white, yellow, yellow/green, black and a smaller yellow wire .. Currently its wired red +, red/white is not connected, black -, yellow/green mag, yellow mag, small yellow ignition key on... Anyone know if this is correct... Also I cant find a wiring diagram anywhere for this... Id like to be able to test it to verify whats the cause of my no start... If anyone knows how to test the coil, magneto and control unit Id appreciate it.... I own a volt meter but dont have any specs on these items with ohm readings.... Thanks in adavance....
