JamieE_M
Well.. *Oh Noes*...
Recently started buying parts to make a go kart at home, secured a 7HP engine, 50mm axle, 2x 50mm bearings, 2x 50mm wheel hubs and finally;
A 10 Tooth Clutch
and
An 80(?) Tooth Sprocket.
My question is this;
Will I be able to use the clutch and sprocket linked below together? Or Did I Really Screw Up Badly, And Now I'm Broke?
And also, if I can/can't use them together, what chain and/or what part should I replace?
Pls Help D: I'm trying to make a go kart to increase my chances of getting a place at uni. ;-; If you didn't already gather, I'm quite budget so, any cheap parts linked in the replies area would be amazing!
Thanks Guys! :3
A 10 Tooth Clutch
and
Thanks Guys! :3
