Hello everybody, I have a 6.5 hp Briggs and Stratton engine that I want to modify and would like some feedback on my proposed plan. I am fairly mechanically inclined and have had a couple go karts growing up but have never opened one of these engines. For my current 6.5hp motor I would like to do the following; remove the governor, billet connecting rod, bigger cam, 18 lb valve springs, remove airbox in favor of a cone intake, larger carb jet, and straight pipe exhaust. I have been reading a lot lately about modifying these engines. My ideal would be to turn 5500-5800 rpm. The engine is from a pressure washer and has the heavier flywheel. I have read conflicting stories on whether or not a billet flywheel is needed for the rpm range mentioned above. So what do you guys think? I am open to your advice/expertise.
