Piston rings for GX110
Would I be able to use worn rings in my engine for a few months until I get the momey to buy new ones? What would the implications be if I do? Would it hurt the engine?
Here is a pic of the engine
dan
Austraila
3 sprockets??? and depends on how worn they are. if there to worn it wont run cus u wont have enough compression to start it
Dan: I have a triplex chain on my kart, so that means that the sprocket is also a triplex sprocket. I know its a bit weird, but that's how I bought it.
Toystory: Yes, the rings that were originally in the engine. It runs OK at the moment, but I suppose I had better dig for some money to get them changed. I was just hoping i could wait a while
As I have no experience with engines, I took it to our local repair shop to get looked at. After having a look at it, they say that the rings need to be replaced. I also got them to have a look at the reduction box on the engine, as it was always engaging, no matter what. I apparently have to get one or two parts in the box replaced.
Russ2251
AZUSA:Powered by LAWN-BOY
Serviceable refers to a minimum compression reading measured in lbs/sq.in.
For example:
My engines normal compression reading is 100-115 PSI (lbs/sq.in.).
The minimum serviceable is 80 PSI.
As long as I am at 80 PSI or above, I do not need rings and engine will run fine.
Oh...OK. I am not too sure what mine is. All the repair guy said to me was that they are pretty bad and need replacing. I think I am just going to have to bite the bullet and get then put in. Less dinner for me for the next month.
Yes, it starts and runs well. That is why I wasn't too sure if I should replace the rings. The repair guy said that when they removed the head they could see that there was some movement (play) in the rings.
Because of this they say that they should be replaced.
sideways
Unfinished projects king.
Perth, Western Australia
Measure the ring gap, if it's less than about 2mm then you don't really need to replace them. Of course, the specs call for a much smaller gap than that but they'l be fine.
Thanks
Hayden
I think we might all have hit the post button at the same time, but the repair guy said that they didn't do compression test, but that they could see from the movement of the rings that they were worn. I am not too sure what the size of the gap was though.
Russ2251
Rings are supposed to have movement.
If engine is apart, then by all means replace rings.
FYI, most of my customers believe that they need rings when in fact they do not.
I am curious as to why your shop would not have a compression tester. This is the most basic of tools.
They said to me that their mechanics are experienced enough to know if the engine needs rings or not. They are the official honda dealers in town, so i am not too sure either why they wouldn't do it.
I am probably just going to tell them to go ahead and put them in. As you say, if it is apart then they might as well do it.
Thanks for your comments
robbie
Osceola, Missouri
Sounds like a great policy. If you have a compression tester, some customers will need rings and some won't, depending on what the test says.
If you don't have a tester, then everybody needs new rings.
