Piranha Build
Gear box
Clarksville, Tenn. USA
Now to finishing it, I'll be needing the floor pan hooking the shifter; I noticed that the Edge has there shifter on the left, I'd like to have mine on the right side. Daddy said, he would use some rod and transfer from right to the left; I didn't understand what he meant but he knows what hes talking about.
Rustydog2010
NZ Nutta :|
New Zealand
You'll probably find that the gear shift on the engine is on the left of the engine. Hence having to take it across from the right, to the left.
redsox985
PA
For the shifter linkage, I would get a long piece of 3/8" or 1/2" solid bar and bend it as needed and add guides to the frame for the bar.
Gear box
Did some riding this weekend, tried to down load video of test run it; Times out and wont let me do this task. Found that it nose dives when breaking and on take off it wants to raise the front up while the tires are on the ground, need to strap the a-arms down or something. Maybe it's because I don't have shocks on the rear that it's causing this to happen??????
Gear box
Now as you can tell I rode this a lot in the last few days it's dirty I have the floor in and painted, and my shifter in.
I'm looking to get an bonnet and my uncle is wanting to redo some of the issues that this buggy has or make a hole new one this Fall or Winter he said he's not sure yet.
Well, first off the price that the Edge has on the rear shocks! I'm thinking if I'm going to spend that kind of money I would like to go with FOX shocks I like the looks of them and they are cheaper.
Have you got shock mounts for the rear of your kart, and you just haven't installed any yet, or would you still have to fabricate some?
Gear box
Have an up date, broke a PTO shaft right up close to the yoke this past week end. Noticed the Red buggy on the EDGE site has CV's instead of PTO's. My uncle said that he do something like that, so he's back to he drawing broad has new front and rear design for us to try. Got my bonnet and most of the buggy painted and now I will have FOX shocks on all four corners very soon. I have most of buggy torn down right now cut out front end and rear end getting ready for the new parts my uncle has for me. Have pics in a day or two, later I gotta get for school..
fowler
Bullsbrook West Aus
the red buggy is a baracuda which is a model up
but cvs are common in piranhas
there is a design for a plate to make the six spline shaft exept a 930 cv
930s are the best as they have the most travel and the easyest to adapt
german cars use them porshe, bmw and voltzwagon
also u can buy them online new from offroad groups
Gear box
:iagree: My uncle said he was using I think he said 944cvs and vw bus axles, but he say that there was changes to made on the existing center and outer shafts
Gear box
Now just in my FOX SHOCKS on all fours, still waiting on my uncle to finish up on my front and rear end parts, hopefully I'll have them by the weekend. Also got my bonnet in too, man this thing is going to be smoking hot LOL
